Navigate between tabs reset filters.
Mathieu Ferstler
Mathieu Ferstler Member Posts: 3
Some of my colleagues encounter a disagreeable behavior when navigating between JAMA tabs.
In the items List view, we can setup filters:
thumbnail image
And when we click on an Item a new JAMA tab opens:
thumbnail image
But if we go back to the previous tabs where our filters are defined, the tab will be refreshed and our filters reset:
thumbnail image
What can we do to avoid this behavior ?
Mathieu
    [Deleted User] Product Team Posts: 334
    edited July 2018
    Mathieu:
    I can see how this would interrupt your workflow. This is a known bug where the filter from search results, selected facets do not persist in a filtered view if the user views another Jama tab. The workaround at this time is: to build an advanced filter.
    This bug has been logged in our internal system with this Community Post associated with it. For your reference the bug ID is: SOS-DEF-1644. You can check future release notes for this ID to see if this bug has been fixed. I can tell you that this particular bug has been chosen to target in a sprint!
    If you have any questions about our bug fixing process, I recommend reading this article in our community.
  • Jacob Breazile
    Jacob Breazile Member Posts: 3
    edited January 2023
    Hi Chloe,
    I understand this is an old post, but as a new user to Jama, I recently discovered that I am also plagued by this problem. As your above post indicated this is a bug targeted for a sprint in 2018, I am wondering if there has been any progress? I cannot find this bug identified in any release notes.
    Jacob Breazile
    Sent: 07-31-2018 16:13
    Subject: Navigate between tabs reset filters.
    Mathieu:
    Business Support Engineer
    Sent: 07-25-2018 04:08
    Mathieu
    edited January 2023
    Which version of Jama do you use? I cannot reproduce this issue anymore neither in 8.79.1 (self-hosted), nor in 8.82.0 (cloud). I remember seeing this in 8.36.2 (self-hosted).
    Sent: 01-18-2023 07:22
    Hi Chloe,
    Jacob Breazile
    Mathieu:
    Mathieu
  • Jacob Breazile
    edited January 2023
    Hi Patrick. We are using 8.73.4 self-hosted. Since you are not seeing the behavior on 8.79.1 I will ask our administrator about updating. Do you know what version this was fixed before we go through the update process?
    Jacob Breazile
    Sent: 01-20-2023 05:54
    Hi Chloe,
    Jacob Breazile
    Mathieu:
    Mathieu
    edited January 2023
    Are you sure about your version? According the release schedule and the release notes, there is no self-hosted version 8.73.4, only a 8.74.3.
    8.79.1 is the next self-hosted version, following 8.74.3. I cannot see a respective note in the release notes but the problem seems to be fixed, at least on our end. Maybe someone from Jama can officially confirm it before you do the update to 8.79.1 or even 8.79.3.
    Sent: 01-23-2023 06:10
    Jacob Breazile
    Hi Chloe,
    Jacob Breazile
    Mathieu:
    Mathieu
  • Jacob Breazile
    edited January 2023
    You are correct, I dyslexic-ed the version. I am on 8.74.3. Sounds like we have an update scheduled for this Friday. I'll post back if that resolves the issue (hopefully)!
    Jacob Breazile
    Sent: 01-23-2023 06:56
    Jacob Breazile
    Hi Chloe,
    Jacob Breazile
    Mathieu:
    Mathieu
