Filter on test case steps being missing/empty
Robert King
Member Posts: 6
I am trying to create a simple filter to find test cases missing steps. The most logical filter would be to filter for Validation Test Cases where "Steps is empty":
However, as shown above, this filter does not work even though I am positive that there are hundreds of VALTC missing steps in my project right now. I assume this is because the default/unpopulated Steps field contains something (?) that prevents this filtering code from considering it truly "empty".
Are there any known solutions or work-arounds to this?
Robert King
Skyworks
Austin TX
Robert King
Skyworks
Austin TX
Guess this isn't possible?
Robert King
Skyworks
Austin TX
Sent: 11-18-2022 12:40
Subject: Filter on test case steps being missing/empty
Robert King
Skyworks
Austin TX
Hi Robert,
What version of Jama Connect are you seeing this with, and what browser(s) (including version number(s)) are you accessing it in?
Sent: 01-27-2023 10:15
Robert King
Skyworks
Austin TX
Robert King
Skyworks
Austin TX
Hi Carly,
Build date: 2021/11/19 15:44 - Version: Jama Connect 8.66.1
Chrome: Version 109.0.5414.76 (Official Build) (64-bit)
Robert King
Skyworks
Austin TX
Sent: 01-27-2023 13:52
Hi Robert,
Robert King
Skyworks
Austin TX
Robert King
Skyworks
Austin TX
Much appreciated, Robert! It looks like you've encountered a known defect, SOS-DEF-5534, "Filter: For Test case item type 'is empty/is not empty' conditions does not return correct results for 'Steps' field". I've logged your experience in our internal system, and you can check future release notes for this ID to see if this defect has been fixed.
Sent: 01-30-2023 09:33
Hi Carly,
Robert King
Skyworks
Austin TX
Hi Robert,
Robert King
Skyworks
Austin TX
Robert King
Skyworks
Austin TX
