Category Name in Velocity Report instead of Path?
Charlotte Dyck
Charlotte Dyck Member Posts: 10
In velocity reports, how do you convert the Category Path from getAllCategoryPathsByDocumentId(java.lang.Integer documentIds) to the name of the category?
For tags I used:
#set( $docTags = $tagDao.getAllTagsByDocumentId($vDoc.document.id))
#foreach( $dt in $docTags)
$dt.tagName
But the synonymous version below doesn't work and I can't find a method to convert the path (ex. com.jamasoftware.contour.categories.model.CategoryPathInfo@2d06b650) to the readable category name
#set( $docCategories = $catDao.getAllCategoryPathsByDocumentId($vDoc.document.id))
#foreach( $dc in $docCategories)
$dc.categoryName
Charlotte Dyck
ON
Welcome!
It looks like you're new here. Sign in or register to get started.
  • lynnebanki
    lynnebanki Member, Jama Connect Interchange™ (JCI) Posts: 7
    edited September 2023
    #set( $docCategories = $catDao.getAllCategoryPathsByDocumentId($vDoc.document.id)) does not even return a list for me, empty or otherwise, for an item ID that I know has Category Paths associated with it. I realize the shape of the list contents varies between tag and categories. Do you have an example of how to access categories for an item by id correctly and, as Charlotte states above, retrieve their names?
    lynne banki
    Blue Origin
    Kent WA
    Sent: 09-14-2023 14:49
    Subject: Category Name in Velocity Report instead of Path?
    For tags I used:
    $dt.tagName
    $dc.categoryName
    Charlotte Dyck
    ON
  • Iwan Kutter
    Iwan Kutter Member Posts: 29
    Hello
    I also spent some time figuring out how to extract the categories. Here is an example of a code snippet that can be used get the categories in an HTML page.  To get only the "category name" out of the "category path", I have used the function Substring:
    <html>
    <head>
      <title>Example Report Categories</title>
    </head>
    #set($docus = $documentSource)
    <table>
    	<thead><tr>
    		<th>ID</th>
    		<th>Category Path</th>
    		<th>Category Name</th>
    	</tr></thead>
    #foreach ($vDoc in $documentList)
    	#set( $doc = $vDoc.document )
    	<tbody>
    	<tr><td>$doc.documentKey</td>
    	#set( $categories = [])
    	#set( $categories = $docus.getAllCategoryPathsByDocumentId($doc.id))
    	<td>
    	#foreach( $cat in $categories)
    		<br>$cat.categoryPathName</br>
    	#end
    	</td><td>
    		#set( $catPath = $cat.categoryPathName )
    		<br>$catPath.substring($catPath.lastIndexOf("/") + 1)</br>
    	#end
    	</td></tr></tbody>
    #end
    </table>
    </body>
    </html>
    Iwan Kutter
    Requirement Engineer
    Sent: 09-14-2023 19:46
    lynne banki
    Blue Origin
    Kent WA
    For tags I used:
    $dt.tagName
    $dc.categoryName
    Charlotte Dyck
    ON
    Iwan Kutter
    Bernina International
  • lynnebanki
    Thank you for the example!
    Is there a version cutoff for access to categories though the Velocity DAOs?
    lynne banki
    Blue Origin
    Kent WA
    Sent: 09-15-2023 08:11
    Hello
    <html><head>  <title>Example Report Categories</title></head>#set($docus = $documentSource)<table>	<thead><tr>		<th>ID</th>		<th>Category Path</th>		<th>Category Name</th>	</tr></thead>#foreach ($vDoc in $documentList)	#set( $doc = $vDoc.document )	<tbody>	<tr><td>$doc.documentKey</td>	#set( $categories = [])	#set( $categories = $docus.getAllCategoryPathsByDocumentId($doc.id))	<td>	#foreach( $cat in $categories)		<br>$cat.categoryPathName</br>	#end	</td><td>	#foreach( $cat in $categories)		#set( $catPath = $cat.categoryPathName )		<br>$catPath.substring($catPath.lastIndexOf("/") + 1)</br>	#end	</td></tr></tbody>#end</table></body></html>
    Iwan Kutter
    lynne banki
    Blue Origin
    Kent WA
    For tags I used:
    $dt.tagName
    $dc.categoryName
    Charlotte Dyck
    ON
  • Iwan Kutter
    I am not sure about the exact difference to DAOs and I'm also no familiar with it. According to my understanding, with the #set($docus = $documentSource) you get the DAO. When there is a report without using the "context", the $documentList is empty. You can get the document IDs like this for e.g. project ID 113:
    #set( $docuIds = $docus.getActiveDocumentIdsInProject(113))
    #foreach ($docuId in $docuIds)
    	#set( $categories = $docus.getAllCategoryPathsByDocumentId($docuId))
    	#if( !$categories.isEmpty() )
    		<tbody>
    		<tr><td>$docus.getDocument($docuId).documentKey</td><td>
    		#end
    		</td>
    	#end
    	</tr></tbody>
    #end
    Iwan Kutter
    Sent: 09-15-2023 10:44
    lynne banki
    Blue Origin
    Kent WA
    Hello
    Iwan Kutter
    lynne banki
    Blue Origin
    Kent WA
    For tags I used:
    $dt.tagName
    $dc.categoryName
    Charlotte Dyck
    ON
    Iwan Kutter
  • Charlotte Dyck
    Using the .categoryPathName was able to convert the path data into the actual category name and is showing up in the report in a readable way!
    Thank you Iwan!
    Charlotte Dyck
    ON
    Sent: 09-19-2023 02:30
    #set($docus = $documentSource)#set( $docuIds = $docus.getActiveDocumentIdsInProject(113))#foreach ($docuId in $docuIds)	#set( $categories = [])	#set( $categories = $docus.getAllCategoryPathsByDocumentId($docuId))	#if( !$categories.isEmpty() ) 		<tbody>		<tr><td>$docus.getDocument($docuId).documentKey</td><td>		#foreach( $cat in $categories)			<br>$cat.categoryPathName</br>		#end		</td>	#end	</tr></tbody>#end
    Iwan Kutter
    lynne banki
    Blue Origin
    Kent WA
    Hello
    Iwan Kutter
    lynne banki
    Blue Origin
    Kent WA
    For tags I used:
    $dt.tagName
    $dc.categoryName
    Charlotte Dyck
    ON
    Alessandro Valli Member, Data Exchange, Jama Connect Interchange™ (JCI) Posts: 840
    edited October 2023
    I have found out you can access these properties:
    • categoryPathName
    • categoryPathId
    • itemVersionIdApplied
    • pathIdsToRoot
    Sent: 09-25-2023 10:01
    Thank you Iwan!
    Charlotte Dyck
    ON
    Iwan Kutter
    lynne banki
    Blue Origin
    Kent WA
    Hello
    Iwan Kutter
    lynne banki
    Blue Origin
    Kent WA
    For tags I used:
    $dt.tagName
    $dc.categoryName
    Charlotte Dyck
    ON
Welcome!
